Skylarking
- Feb 3, 2018
- 10,125
- 10,583
- 113
- Age
- 123
- Location
- Downunder
- Commodore Motorsport Edition
That’s a nice bit of data you've presentedI have done the calculations based on the info I can get when I was upgrading the brakes. AP info was a bit hard to get so it may not be the accurate figures. But the and brembo,pbr & mando caliper specs i'm confident.
Bottom line is that I have ran the brembo 6/4 pot combo on a 25 MC and it was signed off by the engineered
So I would say don't worry unless you plan to upgrading to a bigger kit being the AP 6 pot kit which would require more volume
What would also be interesting is the BMC shaft travel for the given 0.5mm brake pad movement as that depends on the BMC diameter.. And from that we can work out the brake pedal movement we’d experience with Brembo‘s all around given a 25mm and 27mm BMC (assuming the pedal parts and thus the leverage are all the same across the range). Even better if the pedal movement and pedal pressure can be calculated (assuming no vacuum assistance).
(Don‘t know if there are differences in the vacuum booster between the vehicle variants or whether they are all one and the same…).
