That's a really good explanation and I had the same thoughts about the fuse being the weakest point. Is there a way to buy a new fuel pump and connector and convert the crappy connector to one that can handle the voltage/amps better?
Correct me if I'm wrong but the problem is on the loom that comes with the car? Buying an aftermarket pump that utalises the stock loom will still pose a threat? My thoughts is it get a pump that (and I'm simplifying my thoughts here) has a bigger connector and then we change the stock loom connector to a bigger heavy duty one that's rated 20amp?
I haven’t looked at the fuel pump wire gauge or the connector size myself but there are resources you can find on the www that specific the current carrying capacity for wires and for connectors used in automotive applications. Using such resources, one could check the design and quantify what current carrying capacity headroom exists above the fuse rating (if any).
It may be that the standard wire size is ok for the intended current carrying capacity. It may even be that the connectors current carrying capacity is also ok. It could just be an issue around the connectors being from a bad batch of poorly manufactured ones that don’t quite achieve what the specs say they should achieve.. Or it could be penny pinching gone a little too far (thinner wires, smaller connectors)… Really, only Holden knows which is the truth but they’d never say… Unless someone who does such automotive circuit design as their day job looks into it and posts the results of their investigation we’ll never really know either…
Whatever the case, if the fuse is 20A then you’d expect a wire‘s capacity and that of the connector should provide some headroom above this amperage so the fuse will always be the sacrificial lamb (so to say)… Unfortunately we just do know why these connectors fail, only Holden does.
Any direct replacement after market pump would be using the same connectors as the standard pump that makes it an easy plug and play swap (though it’s not easy in a VE/VF). After all parts suppliers don’t want to make it harder for people to use their products… In this context, the best you can do is install an access hatch in your VF which makes doing pumps and/or checking connectors a much easier thing (to the point any design/manufacturing deficiencies can be lived with)…
One can always do a big fuel system upgrade and run another non factory styled fuel pump, filter and other bits including new wiring with it which can be beneficial if they want the headroom for future engine upgrades.
@07GTS has a nice build thread which goes into his fuel system design and engine build (if you want to go down that path). He’s also added two nice access hatches in his VE to make serviceability of his upgraded fuel system a little easier
. He’s the man to answer questions about fuel system upgrades
