308 with VN heads problem
VHCOMMO87
VH SL/X
Hey all got a 308 with VN heads going into the VH just wondering can I bolt up the power steering pump that was on the original 253 onto the VN heads or do I have to use a power steering pump from a Vn - vs ?????
Cheers Tom.
Smitty
Moderator
Bayside Melbourne
GenF SV340 R8 Tourer, VK race car, ZX12R
.. same pump
but watch... the later VN - VS use a metric line out
VB-VK use imperial sizing
VHCOMMO87
VH SL/X
.. same pump
Cheers mate, so the original bracket from the 253 that holds the pump should also bolt up to the VN heads??? Are the bolt holes on the front of VN heads the same as a 253/308 heads ???
Immortality
Staff member
Sth Auck, NZ
Yes, I put a VN pump bracket on a 308 with B cast heads.
gtrboyy
vt ss & lc gtr
Early p/steer equipment can fit,just neater & simpler to use later model vn-vs k frame,steering rack,pump,lines etc
Clearances will be ordinary if not hit fitting decent extractors & keeping early p/steering rack/k frame
VHCOMMO87
VH SL/X
You sure about that? I just spoke to my mechanic and he said that headers will fit up fine using all the earlier equipment with the VN heads, he said he has done it before..
These headers say they fit
