Jas.G
- Apr 17, 2011
- 47
- 9
- 8
- Location
- perth W.A
- VN V6 4.3litre
Better do some more research more next, JEPistions will make a "true"flat top piston for you if given the basic measurements of what you need, as i looked into it early last year for my v6 stroker...2.5mm was as close to 'true' flat tops as I could find [email protected] is bugger all more than 212 hardly worth the money to swap, even mine is annoying on the street but in my opinion it is a very good cam for what I use it for, it's thirsty as it is and still a daily, I wouldn't bother putting a different cam in it when I can change nitrous jets in 5 mins and gain 50hp
Also if that camshaft grind is annoying an thirsty now, i'd really be looking at the tune or other area's as that is very small for a cam with these engines an the comp your's has... my very 1st 3.8l had a grind close to those spec's an had very good driveability and was respectable in fuel economy, even after i fitted 1.7-1 rocker (from 1.6's) it remaind mild
