vt1538
455rwhp LS3
- Sep 28, 2005
- 897
- 23
- 0
- Age
- 55
- Location
- The Dead Centre
- VY SS S2 11.284@125mph
$1400 was for the clutch & flywheel assembly only. You really should replace the master & slave cylinder while you are at it. Brad (enhancedss) will hopefully be able to give you a more up to date price on this as he fits them regularly.
Slipping the clutch is when you dont allow it to clamp 100% instantly. It is a slow timed release of the pedal once the friction point is found. Some use the handbrake, bring up the revs & slowly release the clutch pedal until they feel the car wants to move, hold that position until the last amber, then release the handbrake & simultaneously release the clutch pedal before going WOT.
Myself I just use a slow dumping of the clutch without the handbrake. This is just releasing the clutch pedal on the last amber with some resistance to upward travel. It takes a lot of practice to get good 60 footers coupled with a fast reaction time with either method.
