96 vs v6 coolant overflow bubbling
Brock777
Tamworth
1996 VS 3.8L S2 Equipe / 2002 VY 5.7L SS S2
so my coolant bottle bubbles after turning the car off even tho my car has only sat on normal operating temp, i have replaced the water pump, thermostat, radiator and bled the coolant from the thermo housing to the point where there’s no air coming out. i have no leaks and my pressure test was just fine, i also have a problem with disappearing coolant from the overflow bottle. any thoughts?
Lex
Geelong Victoria
VT Executive S1 V6 6 speed Auto Wagon
Radiator cap.
Maybe (lim ) = lower intake manifold gasket.
Brock777
Tamworth
Radiator cap.
recently replaced the cap too as the old one was leaking, as to the lim any way i can easily check that
Immortality
Staff member
Sth Auck, NZ
HSV VS Senator, VT s2 Exec, VX Calais II L67
Try another radiator cap.
Immortality
Staff member
Sth Auck, NZ
I had nothing but issues with Trident radiator caps on our old VS. CPC worked fine.
Also have a really good look at the radiator filler and look for damage on the sealing surfaces.
shane_3800
35
places
vr commo
That's because the cheap ones test at 10psi out of the box.
Most cooling system pressure testers have adaptors for doing the caps
LYV Y R
60
Emerald
VY2 SS Ute
Sounds like head gasket?
Did it get hot 4000 kms ago?
Fu Manchu
WA.
Trident are junk.
  • Like
Reactions: Lex
