christine cole
- Jun 21, 2021
- 43
- 2
- 8
- Age
- 47
- Location
- eden nsw 2551
- vx, vx supercharge both 2002 , ve 2007
I am coming up for rego and just want it to pass how do I reset the abs on a ve pls
I I will be asking later how to fix properly later but just want a pass
You can’t. The fault has to be found and then repaired.I am coming up for rego and just want it to pass how do I reset the abs on a ve pls
Thanks for that could i trouble you of asking what a fair price to look for this or how to even ask how to fix itYou can't reset it until it fixed.
Unfortunately we can’t guess to resolve that. The cars network is complex and requires a lot of skill to fix.
The only hope you have without that is to guess and parts swap and hope like hell after heap has been spent, that you fix it.
Low battery voltage
Faulty alternator
Poor battery health
Faulty sensors
Faulty ABS module
Damaged wiring harness.
To replace the ABS requires some specialised equipment and I’d expect 3hrs labour minimum ($~$500) plus parts, plus diagnostic time
$150 to $1500, it will depend on what the issue is. The problem is an unknown and could take an hour to fix or 10 hours + to fix.Thanks for that could i trouble you of asking what a fair price to look for this or how to even ask how to fix it
As already said, you have to fix the fault to get rid of the ABS warning.I am coming up for rego and just want it to pass how do I reset the abs on a ve pls
