after marked dizzy
crabby
52
traralgon
vs series 3
evening all ,
i am having trouble finding the plug that goes into the hall effect sensor plug on the ute running a 5 liter from a vq( the one on the loom) as mine is stuffed. i bought a replacement dizzy and has the blue oval hall effect sensor attached to it but can not find the plug that goes into it anywhere and im not paying 250 or more for a complete loom for one plug. so i am wondering if there is an after market dizzy i can put in its place ???? like this one ...here... so i can bypass the plug
thanks
crabby
Immortality
Staff member
Sth Auck, NZ
I wouldn't be using anything from that supplier period.
You still need to plug into the factory loom because the PCM needs a timing signal for everything to run properly.
crabby
52
traralgon
vs series 3
thanks for the heads up :) do you know if you can do a swap from the older blue oval plug to the newer black square plug on the dizzy ? i can get the other half i need with the black sensor but cant with the blue sensor without buying a whole loom ? i can just buy the sensor kit then
thanks
Vs hsv manta
40
Mackay
Vs hsv manta
Look up - EFI hardware
They will be able to supply you with the plug you need
crabby
52
traralgon
vs series 3
thanks , will give them a ring today :spot on:
crabby
52
traralgon
vs series 3
no luck yet again , rang efi hardware and they dont stock or have that part available
back to the drawing board
thanks for the help
Immortality
Staff member
Sth Auck, NZ
