sixshooter
- Jul 22, 2005
- 2,061
- 28
- 0
- 2x VS
AirStrike said:Plan is for a fully manualised T350 later on.
Why are you choosing a Turbo 350 ?... I know they can withstand some punishment and are meant to have less power losses than a Turbo 400 / 700 - as a mate of mine had a manualised T 350 behind a tunnel ramed sb chev in his HK monaro. The downside however, is you loose out by not having the overdrive 4th of the Turbo 700... this is most noticable if you also have a low 4.11 diff ratio when you're on the highway stuck reving in 3rd. Also I was reading the other day that it isn't hard to manually activate the 4th gear lockup via a switch so you can stop slipping in an out of overdrive near the shift point by turning it off for when you really need 4th. Just my 2c.
