diagnosing sun sensor issue vr calais
According to my climate control diagnostics there is a problem with the sun sensor. It's been intermittent for a while.
So I levered the sensor out from its hole, and while it is working OK (no "X" in the display) there is around 4 -5 volts between the orange lead terminal and earth (or between orange and black).
In diagnostic mode (when the sensor os OK) you can see the sensor change its value as you shine more light on it etc, and when it is OK, the aircon works just fine.
But when it is failing, there is no voltage there at all, the aircon then works overtime and there doesn't seem to be any temp. control happening.
I believe the sensor is a light sensitive diode - and it definitely conducts only one way.
But why no voltage? If it was going open circuit that voltage would be much higher, maybe 12V. And if it was shorting, it'd be dead all the time surely. My experience with dud diodes is they they are either shorted or open circuit and nothing in between.
So before I buy a new sensor (about $70 new!) I was wondering if this indicates a problem elsewhere, like in the climate control module itself???
I have checked the plugs/sockets going to the climate control, all connections look good.
