hi there if you have the factory gas fitted to a commodore(there will be a plate riveted to the passenger side strut tower or just above the o/s head light)you HAVE to keep the original airbox and fitler,because the holden computer which also controlls the gas is calibrated to suit the factory setup,I have found that using the pod style fitlers cause leaning out problems.also the impco gas mixer relies on a sight vacuum caused by the airfilter to work properly,if you put a pod filter in there it reduses the vacuum.It is not a good idea to leave the hose clamps on the inlet pipes loose for the above mentioned reason.Ignition problems cause 99% of backfires on LPG vehicles, start there!!!
ps any other LPG questions feel free to ask!!!
ppss the factory holden setup is the best lpg setup ever,when it is tuned by someone who knows what they are doing.....................like moir.
