Bertha
- May 19, 2012
- 6
- 0
- 1
- Age
- 45
- Location
- Ballarat
- VT Berlina
Hi All,
I recently bought a 2003 VY Berlina.
I used the instructions HERE to connect my Kensington AssistOne iPhone cradle to the stock Blaupunkt 6 stacker. The cradle is mounted via a suction cup to the lower right of the windscreen.
I was powering the cradle through a usb adapter via the 12v power socket located in the centre console. But I was getting a lot of noise (humming mostly) that was unbearable.
So I went to an auto-elec to get a 12v socket wired in under the dash with a noise suppressor.
Now the noise is even worse. It sounds like a supercharger. Assuming it's alternator whine. Silent when on accessories only, low whine with the engine on, rises whenever I rev the engine.
Any ideas how to fix this issue? I'm pretty sure everything else is stock.
The weird thing is if I plug the usb power cable into a laptop I get crystal clear audio. So it appears to be an issue with the power source.
FYI, the cradle charges the iPhone via a standard 30-pin iPhone connector. The audio is delivered to the dock via Bluetooth and outputted via a 3.5mm stereo headphone jack to the car audio system. The Bluetooth means it can output audio even when the iPhone is in my pocket, so I have tried it without the phone charging, No change.
I have set one of these up in my other car no worries.
I have only had the car a few weeks. Apparently the alternator was replaced a few month back.
Any ideas on how to eliminate this noise? All other threads seem to deal with people who have installed new head units.
I hope that's enough info.
Thanks!
Thanks!
