"ambient Temperature" Sensor Location...?
MaNiac_VP
Mr Moderator !
www.justcommodores.com.au
VPII Calais
QUOTE (brettkp @ Jan 26 2004, 10:01 AM) Does the amb temp sensor serve any other purpose than to tell you the outside temp? I remember that the intake air temp sensor is also used by the climate control system. Would this be effected (either good or bad) by a cold air kit?
Brett
It basically tells the C/C system whether to draw air from outside or not with or without conditioning it first.
Ie, if you set the C/C to 18 degrees and its 2 degrees outside, it will recirculate air inside the car, but if its 18 degrees outside, it will pull air from outside.
It is used by the system in Auto only mode.
Cold air intake system wouldn't affect it at all i would think.
