Are 8 bolt and 10 bolt Salisbury gears interchangeable?
saladine1
VT Berlina S2 5.7
Just wondering if I can use 10 bolt diff gears in my small Salisbury diff?
I have the small 2.78 diff at the moment and i'm looking for 3.36 gears for it.
Thought i'd ask here first before doing anything.
Thanks.
SL/ENUT
The SL/E Fanatic!
41
Burnie, Tasmania
VB SL/E 5L
No. Sizes are completely different. 10 bolts only fit 10 bolts, 8 bolts, 8 bolts etc
Guzzoline addict
vr v6
No. That's sort of like asking can you bolt a 4 stud pattern wheel onto a 5 stud pattern axle:rofl2:.
saladine1
VT Berlina S2 5.7
Thanks fellas, much appreciated.
Smitty
Moderator
Bayside Melbourne
GenF SV340 R8 Tourer, VK race car, ZX12R
Thanks.
sssshhhh... no one told you that 8 bolt gears from a Salisbury
are interchangeable with banjo gears??? :)
ajvx01
North east Adelaide
308 vc
Why not go borgwarner?
Guzzoline addict
vr v6
Yeah get rid of the 8 bolt salisbury they are far to dangerous.
saladine1
VT Berlina S2 5.7
Smitty to the rescue!
So I can put Banjo gears in my diff?
There's a set of 3.36's on Ebay at the moment. I'll snap them up?
Only reason why i'm sticking with the small diff is because of originality. I do have a VL V8 diff sitting in the shed though..
How so?
Guzzoline addict
vr v6
The diff hemisphere is larger and stronger than the banjos. So when the spider gears pin snaps, it can easily get out pass the crown wheel and hit the pinon gear.This causes the back wheels to lock up.I have had it twice where the pin snapped, didn't make any noises then later on come out and hit the pinion gear.Once when doing a 100 kph down the freeway and the other time pulling up to a set of lights.
