Don’t. Use 5W-40 or 5W-30.
It’s seriously bad advice to use thicker cold temp oil.
The Alloytec is a high tolerance engine. It’s not a clunker 202.
The chains in the video are absolutely rooted. That happens because a few things coming together.
1. Poor crank case ventilation. There is a fix for it, but in your case you need a priest, not a PCV fix or 10w-30.
2. Infrequent oil changes/poor service history.
3. Clogged oil galleries due to both the above. That leads to poor tensioner oil pressure. That leads to a stretched and rooted timing chain.
4. It is a collective consensus among us enthusiasts that service intervals need to be done at 5000-7500. Not at 10000 or 15000.
