bad throttle response on alloytech vz
glenny1988
VZ v6 Executive alloytech 04
hi there do u offer anything for the vz alloytech,my throttle response when i put my foot down is pour the delay is terrable iv cleaned it and even cleaned injectors thinking this was problem still no ood what do u suggest?
kind regards!
Adelaide, SA
00' WH Stato LS1 A4
I used to have a VZ SV6 alloytec 190.... got it dyno tuned for $650 and they were able to change the throttle response, that fixed it up.... it used to have a flat spot.
The software they used was VCM Suite so any tuner that has it should be able to tune your alloytec if it's a VZ.
Willall racing here did mine here in adelaide.
glenny1988
no not always only noticed it sinse 160000 kl so yeah i dunno why this is so!
MACE
I didn't initially recommend a tune as it may "mask" the underlying problem with the car.
As to why it would be causing this problem it would be a number of reasons hard for me to say without looking at the car. Maybe it could be your spark plugs which are sad etc.
On this note I would probably recommend some companies to take a look at the issues personally
Given you're NSW I would recommend the following companies (in no particular order)
Generation Motorsport
Castle Hill performance
Silverwater Automotive Services
Steve
glenny1988
i live in newcastle so all those places are a far distance away
kngsv6
VZ SV6
i was looking for a dyno/vcm tune.. do u kno any good place preferrably in melbournes north or west that tune alloytecs
