Tasmaniak
Not a valid input....
- Apr 30, 2005
- 8,094
- 131
- 63
- Age
- 41
- Location
- S.E. Melbourne
- Website
- www.ranjinstallations.com.au
- VR Stato, C180 Kompressor, Prado and Ka
Npn will have a ground on emitter.
Power transistors MUST be heat sinned, especially if going into the engine bay of a car.
Yes it needs to go into a plastic box. Available from jaycar also.
You can pick yourself up an experiment board that we call a "breadboard" you insert your components into it and use small jumper wires to connect everything together. Once you're done, I would then move it to a small expermenters pcb which will allow it all to be soldered to a board and made into a neat package that can then be mounted into a box. Point to point wiring is not OK in this instance.
