ari666
250,000 hits
- Mar 10, 2009
- 11,835
- 128
- 63
- Location
- melbourne
- 1966 impala, R32 GTR
if you were to install the injector in the plenum then running off a single injector pulse wont spread it wide enough, the further from the the cylinders you can stream the water, the better (in this instance)
if you want the injector to stay on, it will over heat the coil and kill the injector. itll have to be changed for a nozzle and spray controlled differently.
if you find you need to use more or less water, you can simply dial down or up the water pressure
tsunamix: how did you measure the new lower temperatures?
i was under the understanding that this thread is about making a water injection system from stuff you have laying around or is cheap to source (garden hoses and spare fuel injectors etc) not "i wanna do the same water injection system as tsunamix's boosted rocketship"
i for one am enjoying just the discussion, and am keen to see how it all turns out. if its **** and doesnt do anything (other than cut fuel consumption) then meh, whats he spent? 50-60 bucks and a few hours online?
