TheVsStig
- Jul 25, 2014
- 108
- 0
- 0
- Location
- Hervey Bay
- Vs 97 wagon
i think the pump holds a pretty constant pressure. when i tested it i just wired the pump to the battery, the w injector was just plugged into on of the fuel injector plugs and a bottle of water to feed. the higher the rpm the better the spray pattern, it is almost like the 2nd pulse of water being so far up the ass of the 1st pulse, mists the 1st pulse and then the 3rd pulse mist the second pulse and so on. no i haven't tried running the injector at higher pressures as i don't have the appropriate switch to do so.
btw i think that pump has like a 2psi drop at most before it kicks back in. so i would be pumping up to 17 then dropping to 15 before it pumps back up to 17. when the pump was kicking back in it was bring the pressure back up within maybe a quarter of a second, and i couldn't see any difference at all in the spray pattern when it kicked over. there is a fine tune adjustment on the pump that can adjusted up to +/- 2psi, to make very accurate changes to pressure (i could change from 17psi to 17.5psi if i wanted). also the pump can hold a constant pressure of up to 80psi at 4.3 Lpm
