ephect
Donating Member
- Jul 27, 2006
- 5,970
- 15,752
- 113
- Location
- Melbourne
- VS Acclaim V6
with some of the info posted, i've had a bit of a think.. working on the continuous spraying, which the ratio/pressure wont be able to be changed as yet..
you have the pump, hose, scrap the injector and go for a misting nozzle. if you take the feed from the TPS you'll need another jaycar kit, work out what 1500rpm is in voltage from TPS, then have that activate the pump for misting.
what i havent found as yet, is a module/way that you can feed voltage to, and say reference a table, which in turn would up the line/pump pressure to increase the amount of mist. IE 30% throttle add 10psi, 40% throttle add another 10psi etc..
EDIT: i wonder if a malpassi style regulater would work in increasing the pressure to the nozzle based on vacuum
