Battery goes flat
manualwagon
manualwagon
Mooroopna Vic
VE V8 calais, 2017 Triumph Tiger. 2023 Jolion HEV
2007 6lt Calais, if left for more than a couple of days the battery will be flat, have killed two batteries over the past couple of months, both were totally flat would not accept a charge. Now have solar trickle charger on the parcel shelf and leads direct to battery, still have to run it every day. What could be drawing enough to flatten the battery but not overheat anything?
lout
60
Langwarrin Victoria
usual cause on ve is door actuator not locking leaving computers powered up
is this stock electrically, no amps, headunit changes
is this a new fault or since you owned it
ZXTC
VE SSV Sportwagon
There was a post a few weeks ago about a faulty air cond relay draining the battery overnight.
manualwagon
manualwagon
Mooroopna Vic
Thanks, its bog stock, its a 'new' fault, all doors lock. Had auto elecs check it , alternator charging correctly, unable to find anything nasty, they checked local GM to find out if there was an update on alternator not charginn to full capacity, there is so will check thst avenue thanks again
shane_3800
35
places
vr commo
Did they check current while at sleep?
