Beeping every time I start my 99 VT Holden Commodore
almadden
1999 HOLDEN COMMODORE ACCLAIM VT
Have serached the forum but can't find any thing like this . Hope this isn't a duplicate of question already .
For the last few months this has been happening to my 99 VT Holden Commodore every time i start it up.
Thought it might be my ABS modual so replaced it but still happenig.
Any help at all would be great . Thanks
[YOUTUBE]fQsNXXmIPBY[/YOUTUBE]
Jxfwsf
Aus
commodore
Problem with the cluster, best get your hands on a tech 2 and find out why it's displaying "serv Error"
It's slow to turn off the warning lights (cel etc) alternator in good condition? one chime i recognise as oil pressure.
Unless there's another way, as i have a tech 2 i've never had to worry about other methods so someone else may chip in with it if possible.
accentstencil
71
Caboolture South, QLD
WH II Caprice, 5.7 2018 Equinox LTZ V
Probably airbag warning. There should be a warning light as well.
Hangman
Aspiring Sociopath
Newcastle, home of Toranafest
WK Land Yacht
First lot of beeps is airbag warning.
Second lot is either temp or low oil warning, can't remember which (both? Do they use the same warning?) haven't heard it for a while. Thinking oil...
edals
2nd is also same for the hand brake if pulling up while driving. Think also for fuel since the gauge is very low.
lout
60
Langwarrin Victoria
possibly cluster or abs module
start with display diagnostics
Hold mode and up then key on
Release buttons
then
Press Mode = Dash Part Number - e.g. 1731
Press Mode = Mode Switch Voltage - e.g. BV - - - 5.0
Press Mode = Battery Voltage - e.g. V 11.8
Press Mode = Petrol Sender Voltage - e.g. FUEL 02.6
Press Mode = LPG Sender Voltage - e.g. VL 5.0
Press Mode = Remaining Fuel - e.g. 38L
Press Mode = Instantaneous Fuel (Liters per Hour) - e.g. 12.8 L/H
Press Mode = Engine Coolant Temp - e.g. 63 C
Press Mode = Vehicle Speed - e.g. 45 KM/H
Press Mode = Tachometer - e.g. 2380
Press Mode = Park Lamps Switch - e.g. P OFF
Press Mode = Dash Trouble Codes - e.g. t 00 (Press up/down to scroll through any codes, these are not PCM, ABS, etc codes)
Press Mode = Dash Test - All gauges will move, lights will come on and buzzer will sound.
when you get to dash trouble codes use down arrow to scroll through
these are CLUSTER FAULTS NOT ECU FAULTS
if - - after code means ok
if hc means faulty
nu not used
i suspect you have t08 hc
accentstencil
71
The video was not visible to me yesterday (just a plugin vulnerability warning) but after watching it I change my plea to ABS module.
lout
60
Langwarrin Victoria
what suburb of melbourne are you as many of us on here have tech2
BlackVXGTS
Melbourne, SE
Well, my money is on the airbag (SRS) module.
almadden
Hi lout live in Edithvale. Went through the codes n got t08 hc , t09 hc, t11 hc , t12 hc , t13 hc , t14 hc , t17 hc & t19 hc
