Commotion
- Jan 7, 2006
- 53
- 0
- 0
- Age
- 37
- Location
- beenleigh
- 04 WRX
lag is only something that occurs when a motor is built to make big power. being low compression and the types of cams etc causes horrid power down low until boost which then increases the mean affective pressure making all the power up high. you stick a turbo on a standard motor there is no lag its just the same power that it had prior to turbo up untill 2500-3000. my car has the intake pressure just passing the 0 mark at 2500 and is at 8psi by 2900-3200 depending. you want lag you get a centrifical blower. you have to wait till redline before you get your max boost and at 3g where mine is making max boost a centrifical blower would only be making a pound or two. plus when at the drags that bit of dosile power low in the revs can give the car time to get some momentum before all the power comes on. i hate it when people use the term lag to bag out turbos as the obviouldy have no idea about what they are talking about.
