big 3 for a vn v6
ti09ny
Orange N.S.W
VE SV6
i want to upgrade the big 3 in my commodore
its a vn v6 where is the engine earth point?
ti09ny
Orange N.S.W
VE SV6
The big 3 is when you upgrade the charging system in your car for up to 25% more power
You up grade the alternator wire the ground to chassis and ground to the block... I just wanted to know where on the block is the earth point
Nic92
WA
www.youtube.com
2005 Mitsubishi Evolution 9
for the engine block, i posted on a audio forum and some1 said
"pull one of the mounting bolts for the alternator out (might need to take your serpentine belt off for that though) and sand the metal around the bolt hole on the alternator and ground it there. Then run the ground to the factory grounding point by the battery, making sure to sand that down to bare metal too. Then another wire from the factory ground point to the battery negative post."
