Trikky
- Sep 10, 2009
- 360
- 4
- 18
- Location
- Central Coast
- VF S2 SV6 Manual
what brand of cam do you have? unless you are trying to chase every last once of HP out of the engine the dot to dot method works fine(just use the dots on the gears) in nearly all cases
Only time it can be an issue is if the cam was ground offset, but if you have a crow or comp cam you should be fine
When I built my engine I just did the dot to dot method with a rollermaster timing chain and a comp cams camshaft and it has been fine
If it is the cam bearing that has failed I would suspect one of the three things to cause it cam bearing not sized correctly or damaged when fitted (did they have the cam when the bearings were installed) or one of the cam bearing oil feeds has gotten blocked but if this I would expect this from something left in the oil galley and to happen almost straight away not a couple of years down the track
Do you have an oil pressure gauge fitted? what sort of oil pressure does it have at idle and while driving if you do have one fitted?
