Great camera is flat.
Anyway the results are this. Serpentine belt off, cleaned rockers near the pushrods oil feed hole.
Most off them filled up pretty fast, the drivers side closest to the firewall rocker took twice as long as the rest of them. For some strange reason, car sounded more rough-ish, no idea why. And oil pressure was 70psi at idle now. WTF?
Oil pressure will be higher when the oil is cold. That's a good thing.
running a little rougher can be because the alternator isn't working so the system voltage is down, although it might not be directly related to your problem, what sort of condition is your battery in. While we are on that subject the ignition system, have you pulled the plugs and taken a look at those?
As for the oil thing, the engine feeds oil into the passenger side lifter galary at the front of the motor, it then goes along the block, through the passage in the rear block cover (that also used to feed the balance shaft bearing) and then into the drivers side lifter galary at the back of the engine, so the last lifter to receive oil if the front drivers side lifter.
I guess you could pull the rockers and push rods out of the rear drivers side cylinder and pull the injector plug and see what it does, this is how the active cylinder management works on the LS engines, it basically lets the lifters bleed down so they don't open the valves. I've never tried this though so I can't guarantee that it will work.
PS. don't run it to long without the serpentine belt as no coolant will be circulating and you don't want to cook the engine.
cheers
