hako
Donating Member
- Aug 1, 2004
- 8,020
- 96
- 48
- Age
- 80
- Location
- Toowoomba SE QLD
- VS11 BT1 V6
Wont matter closing the bleeder before you let the pedal up. If the hose is in fluid there is no way of air getting in. Someone please correct me if I'm wrong.
Air can get in under certain conditions - if the bleed hose is too long and the first stroke of the pedal does not pump all the air out of the hose the remaining air in the hose will rise up the hose and enter the caliper. Safest way is to close the bleeder at the end of each stroke before the pedal returns.
Also do not reuse the fluid as the bleed process fills the fluid with tiny bubbles!
A mate of mine does trucks - bleeds them the opposite way by forcing fluid in thru the bleeder and up to the MC....something to do with the length of the lines (only on certain trucks).
