No worries dude. Makes things easier wen some1 helps ya out.
The A/C controls r easy to pull all the way out. But if your not confident then dont worry bout doin it.
I recommend to do the power window buttons though!!!
You would've popped em out to get the bottom half of the dash insert out yeh?
To pull it apart, around the base are little clips, undo them, working your way around the unit. The top will come off, you'll have to pull the buttons up, to get it off completely. The buttons themselves will stay in.
The LEDs r under each button. To remove a button,slide a small flat blade screw driver under one side and twist it a little. Pulling the button up.
Do the same to the otherside, then carefully remove the button as there will be two bits of brass that will fall out. If they do dont worry, its easy to tell where they came from. Then simply change the LED put the button back. Put a little vasoline on the edges, lubes it up a little, I had sticky buttons. Then move on to the next.
Not hard, just be careful. If u decide to do it.
Cheers, Keegan
