indyblue
- May 29, 2005
- 29
- 0
- 0
- VE Omega V
indyblue, do you still have the instructions and can you put them up here
I will look on the weekend and see if I still have them for you.
Do you mean you get in and turn your car to "On" first and then start it after it's done all the checks? If so, the BT will connect when your turn it to "On" and the drop out when you start the car. It either reconnects for me automatically, or I just press the phone button on the wheel to reconnect it. Best solution though is just start the car with one turn of the key... Don't turn it On first, wait, then ignition...
Hmmm... Have you set your phone to not require authentication each time? What phone do you have? Once the pairing is setup and set to auto on your phone, pressing the phone button will connect it if it's not connected or activate voice commands if it is.
Sometimes I forget to turn BT on my phone on before I start so while driving down the road, I turn phone BT on and press the button on the wheel. Connects fine.
Just out of curiosity, did they only replace the battery? Or did they follow the whole recall for BCM and Battery? There is a techline on this THAT THEY SHOULD KNOW ABOUT!!! Could be the source of all your dramas...
