07GTS
- Sep 8, 2013
- 5,002
- 6,679
- 113
- Location
- Australia
- VEGTS BUILT BLOWN E85
flow rate between injectors on a stock engine is almost a non issue and the error wont cause any dramas as your fuel trims error will be far more then the injectors anyway, and yes ALL injectors flow different (even same flow rate) thats why the big company's buy hundreds of them so the can match them up to the closest in batches, some even go further as flow rate is only a bit of what they match u also have min pulse width and pressure offset, voltage offset and temperature offset and that all affects the injector pulse, also injector on an ecu are never held open 100% there is always a dead time built into the control so they dont kill the injectors
