Trevor loves holden.
- Jun 6, 2019
- 3,508
- 750
- 113
- Location
- Victoria
- vs commodore
I know what I wrote and stand by it.
When I googled the different all I can come up with is the same answer I gave you. This is Quoted by a brake specilist.
Basically bleeding the brake fluid is when you open an end of the system(caliper nipple)and compress the fluid(like when pedal is pressed)to get out any air in the system. Fluid is probably good, but has air in the system now.
When you flush the system(some use alcohol)to get all the brake fluid out and clean the system of any traces. This also could be done just by swapping colors of fluid like when you go to Super Blue fluid. What you're doing then is, just getting out all the old fluid that has lost it's properties and is holding water for new fluid. Or perhaps have gone to synthetic, DOT 5 or another non compatible fluid for what was in the brake system before.
So: Bleeding is getting rid of some air in the lines. Flushing is getting rid of all or most of the fluid in the lines.[/QUOTE]
