hako
Donating Member
- Aug 1, 2004
- 8,020
- 96
- 48
- Age
- 80
- Location
- Toowoomba SE QLD
- VS11 BT1 V6
ok guys i have a ??? sorta new to abs so dont know what to expect ....but when i'm braking lightly the cars seems pull sorta thing..is the sumthing wrong ???
You say you have ABS (anti-lock braking system) - when braking like in a panic the ABS is designed to release brake pressure to whichever wheel is locking to provide maximum braking and also to allow you to still steer correctly. You will feel a shaking thru the brake pedal when this happens and you should notice that the wheels do not lock up. If it does it with low pedal pressures as in normal braking then it could be warped rotors as previously mentioned.
Do a GOOGLE search for ABS - the RACV have a good story about it.
