Broken steering wheel controls
Escape-The-Fate
HSV, i just want one
Gold Coast
VE SS, M6
hey all, jumped in my car at work this arvo and went to change song on the steering wheel and the button just pushed through :hmmm:..would it be fixable or will i have to buy a whole new row of buttons/just the next button? and if so how much from holden if anyone knows or should i be able to go to wreckers and pull one off another vz? Also does the entire steering wheel need to come off to change them over?
cheers.
PaulSV6
CHE Tuned 156.8rwkw
Castle Hill
VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
No, the buttons cant be bought individually, the whole assy has to be bought. I wouldnt bother with Holden as they charge around $200.
Yes the steering wheel has to come off!
Calaber
Nil Bastardo Carborundum
Lower Hunter Region NSW
CG Captiva 5 Series 2
Hi Paul
Are you sure the wheel needs to be removed? I've had the airbag off a couple of times and I'm pretty sure the stereo controls plug in at the front of the steering wheel.
However,,,,,,I could be wrong.
torana355
VE SERIES 2 MY11 SSV A6 in IVY GREEN
Ok you can buy the whole assembly for $100 from Holden, just make sure you get tht right one (the manuals dont have the lights on controls and the 5 speed auto has the extra harness for the gear change paddles. You don't need to take the wheel off, only the airbag. PM Phreddy if you want someone in Sydney to do it for you.
Escape-The-Fate
Gold Coast
VE SS, M6
bugger!!..trust the fiddly **** to be expensive and hard to get too..might give the wreckers a ring tomorrow and see if they got a vz lying around i can fiddle with before i pull mine apart:boxing:
torana355
Don't bother mate, you are much better off getting new ones as you are likely to end up with buttons in the same conditions as yours were before they broke.
VesperZ
2005 Holden VZ Berlina
Sydney, NSW
VZ Berlina
Hey just curious which side was it? Cause this happened to me and my volume control side stuffed up, but the other side controls are fine. I'm happy to provide mine to you if your mode/track select side is stuffed. I can also provide you detailed instructions on how to do it yourself as I only attempted mine a few weeks ago.
VesperZ
Sydney, NSW
VZ Berlina
Hi Paul
Only the airbag needs to be removed, then the harness for the stereo control plugs in the front of the steering wheel.
PaulSV6
CHE Tuned 156.8rwkw
Castle Hill
Hi Paul
Hi Calaber,
Prob could, i just found it easier with the wheel off.
