Burnt Tail Lights
5.0L UTE
VS UTE S3 5.0
I've got after market altezza tail lights on my vs ute and the reverse and tail light sections have started to bubble and melt indicators fine. The bulbs are standard, now I can see how the tail lights could do it on a long drive but the reverse lights are never on more than a minute. Has any one else had this problem and are there bulbs that put out a lower heat.
(I would think that the d!*kheads would use a heat proof plastic)
vlv8vic
<---Brad Quaid = internet stalker
Australia
M5
Are they an ADR approved version? Might hold a bit more weight if they are in terms of getting some sort of refund or compensation. You can get lower wattage globes but you'll only end up with dim lights in screwed tail lights.
Not a fan what everyone seems to call Altezzas now but one would hope that even the fakest of fakes on the market wouldn't be so dangerously made that they are falling to bits like yours.
Tas_HSV
Hobart,TAS
VR HSV Clubsport
Put proper tailights back in.......problem fixed
woteva
NEED 4 SPEED
Adelaide S.A.
got any pics ??
5.0L UTE
VS UTE S3 5.0
I've put originals back on but girlfriend bought so wanted to keep them on they look good to. they from auto barn so you'd think they would be adr approved
WogBoyz
435rkw/590rwhp
Cairns, Qld
08 VE SSV M6 Ute
i got some lights as you on my ute man i didnt have that problem you did tho my right one wasnt sealed the left was and filled with water 3 times i got them replaced and they wernt sealed musta been a **** batch i ended up sealing them myself, id take them back if u can and get new ones, i got mine from autobarn too
NORTI
Radelaide
Wildtrak
Nope, just because you bought it from Autobarn, doesnt mean its approved, or legal etc...
Calaber
Nil Bastardo Carborundum
Lower Hunter Region NSW
CG Captiva 5 Series 2
That's the beauty of factory tail-lights. They are designed to take the heat of lamps, withstand our strong sunlight without fading, resist cracking over time. Chinese made auto accessories don't make sense.
