Towcar
- Oct 8, 2013
- 1,069
- 36
- 48
- Location
- Auckland NZ
- VX Berlina Wagon
If you constantly tow with this car, I'd suggest getting some airbags fitted to the rear....This helps keep the rear end adjustments correct....by adding weight to the rear, the rear "squats" down, which effects camber and toe....Adding air to the bags, lifts the rear up, to where it normally sits, therefore preventing premature inner edge wear....
The cost is about $400 to $500 installed, but cheap compared to replacing tyres constantly
I am starting to look into options for setting my car up better for towing. I was going to raise it as it has FE2 suspension in it currently and the new float has a lot more weight in the front than the old one did.
What should I look for, I want to 1, raise it, 2 keep it handling like it currently does, 3 prevent premature inner edge tire wear as best I can.
