Can i put VL Turbo injector rail & injectors on N/A ?
vl_2010
VL berlina
Hey guys i need to get another set of injectors and rail because it could be whats causing my car to play up, just wondering though ive seen turbo fuel rails for $80 and i can get some turbo injectors aswell so im wondering if there bolt on to the n/a engine or theres different mods that need to be done?
M3ZZA
VIC
86 VL Turbo SL soon to be canary yellow bt1 mock
You can fit VLT injectors into a N/A rail there's no difference between both rails.
You can run vlt injectors in a n/a on a standard ecu but they will run rich. (not a bad thing) But if you want to boost them past 7psi then you need a vlt ecu
Adelaide, SA
00' WH Stato LS1 A4
Dont bother with vl turbo injectors on a n/a it will run like a pig and chew the fuel
