Car not starting
Bikeboy1976
47
VZ acclaim wagon
I have a vz wagon and it’s had trouble starting
RAA replaced starter relay and car fired then wouldn’t start the next day
Mechanic cleaned out the throttle body and air filter and car ran perfect
Hours later car was dead
krusing
Melbourne, Bayside
Maybe get is scanned,
as this is a pathway to find a fix/solution.
Bikeboy1976
47
VZ acclaim wagon
Hi mate, no promises but I have a tech2 here in Adelaide and if you are close by, I would be fine with running a scan for you, no charge of course!
Mechanic said he did a scan
Fu Manchu
WA.
A scan doesn’t tell a mechanic what’s broken. It is only one part of the diagnostic pathway.
They still need to perform basic tests on other things as they would have years ago to come to a conclusion.
Fu Manchu
WA.
Common causes:
Low battery voltage in the key
Poor contact between the key and the metal ring.
Faulty sun sensor.
Crank angle sensor fault
Neutral Saftey switch fault
Starter solenoid fault.
Low battery voltage or poor battery health.
