- Apr 15, 2006
- 22,626
- 20,513
- 113
- Location
- Sth Auck, NZ
- HSV VS Senator, VX Calais II L67
sounds like a battery problem to me. if the alternator is putting out 14volts then it's most likely fine. a good battery should show 12.6-12.7volts with the engine switched off. when cranking the starter the battey voltage shouldn't really drop bellow 12volts. if the battery is showing less then 12volts after the engine has been turned off the battery is stuffed. i did have a case of a battery that was still showing 12+volts (engine off) but lacked the ability to turn the engine over properly, time for a new battery it was.
when you first switch the engine off the battery will show a slightly higher voltage then it's true condition, if the battery is tired (but not yet totally dead) it will restart the engine if you crank it straight after you shut it down
