car problems
Discussion in 'General' started by quick308, Aug 4, 2006.
  1. quick308
    quick308 New Member
    gold coast qld
    1999 Landrover disco series 1, 2006 Street Bob
    well guys i was taken my car for a bit of a cruise las night. I jus pulled out of the driveway and because this car has a auto transmission i tryed to change it from reverse to drive. it wld not click into gear. i was sittin there for about 15mins muken around with it b4 it decided to work. any ideas what could have caused this i am starten to worry i have owned 2 other cars with auto trans and this has never happened. the automatic trans and the engine have jus been rebuit so it is strange that it is stuffen up.
  2. bradcad
    bradcad New Member
    VT Berlina & mazda 2 DE
    Have you checked the fluid?
  3. quick308
    quick308 New Member
    gold coast qld
    yeah i checked it when it was cold and it was full. but when i let it idle for a while then check it when its hot it says i have no fluid at all?
  4. bradcad
    bradcad New Member
    Fill it immediately. Must be checked when hot and running. That would b your problem. Check if its leaking anywhere- most likely through the sump pan
  5. quick308
    quick308 New Member
    gold coast qld
    thanx mate sh*t hope i have not done any damage
  6. bradcad
    bradcad New Member
    You'll be right. Their pretty tough
  7. quick308
    quick308 New Member
    gold coast qld
    one more question my trasmission has a stage two shift kit and a 3000 stall converter. since it is not standard anymore is there a better fluid i use for this or it does not matter what i use?
  8. bradcad
    bradcad New Member
    The best?
    I can say without a doubt- PM Lubricants. It's proven to lower running temperatures, further resist foaming and actually gives slightly more power as it doesnt thin out as much when hot.
    And it lasts a hell of a lot longer than normal fluid- after say 50 000k's send a sample to them, get a test (for free) and if all is well she should last another 50 at least. Their tranny fluids are being used in drag cars- and the auto's are lasting exceptionally well.
    Give them a call- (07) 3274 3788 or email info@pmlubricants.com.au They have all the information you need to make sure you make the right decision
    Hope this helps
  9. quick308
    quick308 New Member
    gold coast qld
    ok thanx a heap
  10. bradcad
    bradcad New Member
    No worries champ, they've helped me a lot so I'm only happy to pass it on
  11. satos
    satos Member
    VZ Berlina
    were you on a steep incline,the reason i asked my previous car a vc commodore
    would not let me shift the t bar to drive when the car was on an incline.When the car was on flat ground no problems.
  12. semi
    semi GOD
    WA
    VR exec wagon
    that may have had something to do with the fluid levels- could be low and not enough in the right places when on an incline
