Look into a decent second hand belt driven compressor if you're chasing value for money. Direct drive are typically noisy and don't provide adequate FAD.
Yeah been looking, should have kept my old twin piston belt drive. Haven't found anything near cheap enough. Noise won't bother me for the few times a year I need to run the two comps at the same time. My current comp is not even two years old and TBH even though it's a 3 piston belt drive, it's not a lot more FAD than my old two piston, that is only going by how the blaster won't stay at 90psi for anymore than say three mins, maybe four, then drops and holds around 50psi. But because the tank is 100L I have to wait a decent time for it to fill up to 122psi as that is the max I can tickle it up to before the valve blows off on the switch and the air blows out.
Might have to look at my sandblaster and try and get it using less air or bin it and buy a new one. I wonder if the only thing that would really run it would be a 3 phase 7+hp. The blaster might be too old as well. I wonder if the ball cocks are letting too much air through.
One thing that might help is a higher pressure switch, one that kicks in at say 110psi, before the pressure gets below 90psi and then takes ages to build right up.
Ideally I would get proper decent info on just how much air these tank blasters use and FAD needed to maintain the 90psi working pressure? But TTI have NFI and neither does Tool King unfortunatley......
