Cigarette Lighter Fuse
EEJUMS
21
NSW
SV6 VF Commodore S2
Hey guys, I’m trying to figure out why both cigarettes lighter points are not working in my VF s2 and I’m fairly certain it has to be the fuse has blown. I can’t figure out for the life of me which fuse number it actually is/wether it’s in the cabin or the engine fuse box. Does anyone know which fuse I might need to replace or if it could be something other than a fuse. I’m new to this kinda stuff so any help would be appreciated:)
stooge
wa
Turbo Alpaca
try F29 on the inside fuse panel, page 274 in your owners manual should help you find it.
EEJUMS
21
NSW
SV6 VF Commodore S2
Skylarking
123
Downunder
Commodore Motorsport Edition
Do cigarette lighters in modern cars like the VF also have a fusible link at the rear of the plug?
Old cars of the 70’s did :rolleyes:
stooge
wa
Turbo Alpaca
no, in many cases being at the back is too hard to access.
stooge
wa
Turbo Alpaca
i think you might be right as I didn’t have any luck with F29. Thanks for your reply :)
it is best to just use your owners manual and around page 274 you will have fusebox locations and descriptions of the fuses.
look for words like auxiliary , accessory , ACC , socket and you should locate it and if you have a multimeter you can just test the points on top of the fuse and make sure both points have voltage, it saves having to pull the fuse out.
