Clarification regarding SS and SV6 exhaust
Mickcc
East Gippsland
Calais 2016 Series 2
What's drone?
Google Answer
Exhaust Drone is the vibrating sound that occurs in vehicles most often at steady highway speeds and is caused by the engine and exhaust system vibrating at incompatible frequencies. Changes range from adding mufflers or sound dampeners to more involved changes including exhaust system
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
Google Answer
Doesn't happen on utes...
RevNev
VF II SSV Redline Ute
What's drone?
Constantly hearing the exhaust note in the car and drone are two different things. Drone is a resonance at certain RPM and engine load that drums through your head I guess is a reasonable analogy. An exhaust can be loud and drown out the radio, but it doesn't drone. Likewise, a fairly quite exhaust on the outside, can drone badly in the car and give you a headache over a long duration.
No, Utes don't tend to drone at all even with a mega loud exhaust system. I think wagons are the worst for drone in VE/VF aren't they?
Forg
Regal Peackock VF SS-V Redline Wagoon
Wagons run the same exhaust as sedans don’t they? It being impossible to tell the two apart from underneath?
I guess more noise could get in from the “boot floor” due to there not being a closed-off space, but the resonance would still be the same.
I guess Deity Of Choice never intended the LS series engine with it’s head-design to run on only half the cylinders …
RevNev
Yes, the exhaust acoustics are the same but the potential to drone is how the acoustics react in a particular body type. I can generally tell if someone is in the dunny talking to me on the phone, not from aquatic noises, but a different resonance than if they're in a furnished room.
lmoengnr
Donating Member
Sunbury Vic.
Wagons are just a bigger 'resonant box' version of a sedan. I've experienced drone in a VL wagon.
I think the plastic tub in a ute helps to alleviate the drone by dampening the steel structural surfaces.
RevNev
Mentioning VL wagons, I did a Lukey 2.5" bolt on years ago with the same muffler configuration that didn't drone in a sedan, but the wagon droned quite badly. I think it had a 5" round 12" long resonator at the rear and I changed it to a 16" long 6" round Lukey universal straight through muffler and that fixed the droning. I remember it was the first complaint I'd ever had with a Lukey bolt on in the day, were the best sports exhaust systems you could buy.
