clutch wineing noise??
sully1991
ballarat victoria
96 vs spak 5spd ute
long story short iv had the thrust bearing and carrier and spiggot bearing replaced and my clutch still wines when fully engaged in gear and this afternoon after work has started to do it in neutral any ideas as to what it could possibly be?
hako
Donating Member
80
Toowoomba SE QLD
VS11 BT1 V6
When it is in neutral with the clutch engaged, if you disengage the clutch does the sound go away?........if so, does it come back immediately you engage it again.
