code48?
minimefx
45
vr wagon, vx executive
no signal to cam angle sensor. on vr series 2 v6? check volts to cam angle sensor at plug. all good going by gregory manual. replaced cam angle sensor. all good. replaced dfi and coil pack. all good. replaced leads and plugs. motor still works the same. removed engine fuse as manual says to reset error codes. i have done everthing that the gregory's manual said and still getting error code 48? help please
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
did you change the cam angle sensor or the crank angle sensor by mistake there is 2 on VR just making sure you changed the right one.
minimefx
45
i did the crank angle when i put the motor together and the cam angle sensor when i had the motor in the car and the code came up.
hako
Donating Member
77
Toowoomba SE QLD
VS11 BT1 V6
Maybe try another ECU - they're cheap as dirt nowdays...well, cheaper than a CAS. Or try unplugging the ECU and leave overnight. Is the engine is running poorly or using heaps of juice?
minimefx
45
it just has a rough idle. drives well and 220k to half a tank of fuel
hako
Donating Member
77
Toowoomba SE QLD
VS11 BT1 V6
If plugs and leads or OK I'd drive it and not look for trouble. 220k for half a tank is good. Keep your eye open for another ECU...they go for a little as $10. With what you've replaced already you don't have many options left. Frustrating I know.
minimefx
45
i will get the ecu and some other good bits off the young guy around the corner from me. he smashed his vr and i got the extractors and full 2 1/2" system off it for $100. i starting to think about leaving the error code there as the car is going well.
