prizedbnx said:
anyone got other ideas for Good cold air intakes using the standard box and a k&n panel filter?
i made this yestarday easy and the engine runs cooler, cant feel any power gains but still runing stock filter till next week, runs so much smoother
i used:
under a meter of 90mm pvc downpiping (one end with a bellow on it)
2 45degree bends
and pipeing glue
how to. (sozzy no pics on the progress 4got 2 take some)
1.take the bottom half of the air box out,
2. place the 90mm pipe in the centre where u want it and trace round it with a texter
3. using a drill,drill many hole around the inside edge of the traced circle
4.brake off the centre piece
5. sand the edges till its smooth and the pipe fits in easy and tight
6.place box back in and screw bak down
7.mark the circle onto the metal
8. use a small drill bit and drill holes all the way around (on inside of the line)
9. remove box
10. use a bigger drill bit and goin all the holes
11.sand/file till smooth and 90mm pipe fits
12. get both 45degree bends and a piece of 90mm pipe bout 10cm and glue together to form a 90 degree bend (make sure its straight)
13. usen the bellowd end off the pipe, place it in to the box and throught the metal shelf
14. cut the pipe when the 90degree bend is evan with the bar
15.glue bend 2 down pipe
16. cut a intake pipe to the bar and glue to bend
17. use 2 zip ties and goin them togeter then tie the piping to the braket above the pipe
18. there was a braket in the way of mine so i removed it, didnt do much BUT if ur in NSW or VIC witht he RWC then i wouldnt recomed removn it coz proberly wont pass
