Coolant pipe in inlet manifold
Lachlan3491
NSW
VS Commodore Ute
So I got a question to go with a plan I might have. On a L67 motor where does the coolant run through the inlet manifold? Does it just go in then out to warm it up? Or does it go through the inlet manifold to get to the thermo? My idea was if it’s only there to heat up the manifold would I be able to make a blank and not run that pipe? (Photos below of what I talking bout)
Lex
Geelong Victoria
VT Executive S1 V6 6 speed Auto Wagon
So I got a question to go with a plan I might have. On a L67 motor where does the coolant run through the inlet manifold? Does it just go in then out to warm it up? Or does it go through the inlet manifold to get to the thermo? My idea was if it’s only there to heat up the manifold would I be able to make a blank and not run that pipe? (Photos below of what I talking bout) View attachment 250747View attachment 250748
I think thats the pipe that goes to a heater hose?
Immortality
Staff member
Sth Auck, NZ
That pipe goes from the LIM to the heater tap, the heater core and then back via the heater tap to the water pump. If you are not using the heater core than the coolant loops straight back via the heater tap straight to the water pump. This is important as it keeps the coolant flowing when the thermostat is closed during the warm up cycle.
Lachlan3491
NSW
VS Commodore Ute
So is there a way to bypass it to the heater?
Immortality
Staff member
Sth Auck, NZ
I'm not following what you are trying to do.
Lachlan3491
NSW
VS Commodore Ute
i don’t have that pipe it’s the one thing I didn’t get with the conversion and was just seeing if I can make a black cap for it and just by pass it to save me bending up a new pipe that’s all, and just thought if it wasn’t important and didn’t flow anywhere it would be better to keep the LIM cool instead of heating it with coolant
losh1971
North Tas
VE Series I SS Ute
You can bypass the heater core but if you have any signs of blockage, letting it dry out pretty much seals it's fate.
Lachlan3491
NSW
VS Commodore Ute
Alright cool I will just make up a new pipe then
Immortality
Staff member
Sth Auck, NZ
Ideally you need it there. Regardless coolant flows under/through the LIM
