Coolant temperature Sensor
cacaman
Red is Faster
Vr Acclaim
Im gettin bad fuel ecconomy out of my Vr and it spat out Code 16 - Coolant temperature Sensor voltage unstable.
Can anyone please shed some light on how to replace the coolant temp sensor, id really appreciate it (and everyone else wanting to know how) if somone could show some pictures.
Cheers Rob
holden007
VRII
Subaru Liberty
Assuming its the temp. sensor which send info to ecm; just did mine recently:
1. disconnect the negative battery terminal.
2. take the drivebelt off.
3. drain the radiator water till no water comes from the water pump.
4. remove the alternator retaining bolt (located next to the belt tensioner pulley), and loosen the pivot bolt and raise the alternator up.
5. disconnect the connector (there are two sensors there, its the right one)
6. unscrew the sensor and replace with new one (note: put some of that white tape, forgot name - around the thread of the sensor).
7. do the reverse above, and fill radiator with water and your sweet.
boojak87
VT Series II SS 5.7L
I got quoted roughly $300 to replace the coolant temp sensor on my vs!!! I know this is a rip off...is there anyone in melb that can direct me to a place that can do it cheaper?
Thanks all,
Boojakz.
holden007
VRII
Subaru Liberty
I dont live it VIC, but thats a RIPPER. The part only cost like around $20. Shop around!!!
fonzo
vs berlina s2
i just payed 93 dollars for a genuine sensor at trade price???
TheForgotten
only human......
quarantine
www.holdenscene.com
VR EXEC
you wanna look into that fonzo, they really are only $20-25 from holden
mrhotdog
What Would Jesus Do?.....
Adelaide, South Australia
2003 VY S1 Acclaim
holdens in SA quoted me $100ish for the temp SENSOR, the SENDER is the cheap part (this is the one that tells temp gauge what to show)
aceventura
Doesn't drive like this
SEQ
Mazda 6
Mid last year I was quoted $25 for a genuine delphi temperature sensor. The next week when I went to buy it they wanted $100 - go figure.
BlackVXGTS
Melbourne, SE
I purchased two identical Bosch coolant temperature sensors a few weeks ago. The one from Repco was $22 and from Holden was $16.
