Crank Angle Sensor
Trennaa
35
Melbourne, AU
Qwerty
I was told by a mechanic (not my mechanic, rather, a mate of mine) that clunking in my gears could be due to a Crank Angle Sensor on it's way out.. I know I got issues with it, due to starting problems.. but would this help my Gear Clunking also? It only happens with the Engine Warning Light on.
sircruisealotVS
37
South Brisbane
VZ LS1 Calais
hmm, yeah...i dont understand what the cas has to do with the trans, at all.
clunking in and out of gears is usually due to drivetrain problems.
Doctor Bob
Grandpa
Retired
RG. Colorado & Caravan
no trent, the most likely cause is a fault in the trans causing high line pressure
Rob
Trennaa
35
Melbourne, AU
Qwerty
sircruisealotVS: thats what I thought myself.. but this Mechanic mate sounded quite convincing!
MBS206: Haven't had it checked out to tell you the truth, lack of time.
Doctor Bob: I know when the Transmission was replaced, the cooler lines weren't quite tightened to the way they shoulda been.. is this what you mean?
excuse my mechanical illiteracy.
Doctor Bob
Grandpa
Retired
no more so an electrical fault, is the engine light on?
Trennaa
35
Melbourne, AU
Qwerty
Yes, quite frequently.
While the car is warming up so to speak. first 5-10 minutes of driving it'll drive withOUT the engine light.. gearchanges will be nice and smooth. Engine light comes ON and sharp punchy(sometimes crunchy) gearchanges.
