dobesz
355ssute
- Oct 21, 2009
- 156
- 8
- 18
- Location
- Victoria
- vs ss ute
So been really busy with work, quoting jobs flat out and in process of getting my DBU, so ute has been on the back burner. Put a carpet underlay in that has a alloy sheet in the middle of it, hopefully give evan more heat protection.
Installed my new black carpet and new seat belts. As i have been going have been giving all the plastics a good clean and getting rid of all the built up dirt and dust from years as a work ute. Removed the jack assembly as well and will relocate to inside the tub.
Also fixed the problem of my 12 inch sub sounding mufled and distorting easy I removed covers that block 90mm holes that go between cab and where sub is mounted under tub. These were behind where my amps are mounted. I then have remounted amps over the top but with 15mm rubber spacers so the air can freely move out as before sub sounded not great as not enough air space in the under tub area.
