creaky sway bar
viccib
VN V6 Executive Sedan
Hi guys, i'm hoping you can help me with this one. my son has a '91 vp sedan and everytime he does a full lock it creaks. we think it may be the sway bar moving on the drivers side. when we put it back where it's supposed to be it's ok for awhile and then it starts creaking again. we had the front end checked and everything was fine, do you guys have any other suggestion as to what could be causing this to happen. thanks.
zskinner
WN CalaisV 6.0L
try spraying some wd-40 onto the joint on the steering shaft (its kinda behind/below the brake fluid resorvoir if i remember properly). i had a similar noise with my vp and spraying this area helped alot (didnt completely get rid of it but its a hell of alot better). just my suggestion anyways, good luck mate :thumbsup:
